throttle problem part 2
zancruse
This anoying throttle problem is still there. Ski ( 97 gtx 787) if gunned out of the hole will not accelerate past 36mph or increases rpm past 5000. Throttle pinned, im doing 36mph then I back off throttle then gun it and the ski takes off full power to 58mph. In reverse or hooked up to hose engine reves up steasedy with throttle. It only seems to happen when under full water load. Things done so far. Cleaned rave valves, new fuel lines, fuel filter, prop is new, wear ring good.
Any ideas what to check next?
