So, I know we keep talking about making a How-To thread on rebuilding carbs and never get around to it so last night I decided to finally get-r-done. This will be a work in progress as there are a lot of pictures and text to upload for this so give me a little time. I also welcome any tips and hints that others might have so we can make this as easy as possible for the first timers.
This will work for any of the Seadoo carbs except for the old round body carbs found on the early models and even the Yamaha's.
First off I am going to assume you have removed the carbs and it might not hurt to label the hoses and cables so that you can get them back on. I know some people remove the cable brackets from the carbs with the cables on so you don't have to readjust them.
The supplies you will need are new GENUINE Mikuni carb kits and needle and seats. You can get them from Amazon, Ebay, Site Sponsors and OSD Seadoo parts DO NOT buy SBT, WSM, Wonderosa, Venom, Titan or any kits as they are guaranteed to be junk and give you more problems. All carbs except the 951 use the Mikuni number MK-BN38/44-SPR. The 951 uses different carb kits number MK-BN46I and pop-off springs exclusive to them. You will need new carb to manifold gaskets, new standard black automotive fuel hose in 1/4" for 97 and older 787's, 720's, 650's and 580's. 951's and 98-99 787 use 5/16" fuel supply hose and 1/4" return hose. Nitrile rubber gloves for the cleaning solvents. I like Walmart brake parts cleaner because it is cheap and works great. WD-40 for checking pop-off and some paper towels. I have a notepad and pen to record the settings.
The Tools: Needle nose pliers, flat blade screwdriver (as you can see the tip is ground down for reaching the pilot jet), small phillips, small flat screwdriver and the green one is very important as it is not a phillips but a Japanese Industrial Standard, the reason it is so important is that the Mikuni carbs use JIS screws and a phillips can and will strip them out. I bought this one on Amazon. You will also need to buy or make a pop-off gauge. As you can see mine is a brass tee, a schrader valve, a barb for the hose and a 0-100 gauge from Harbor Freight, I then use the bike pump for pressure. An air compressor and spray nozzle or some canned air if you don't have a compressor. Also some razor blades, maybe a small pick. Safety glasses as brake parts cleaner burns really bad in the eyes. Last is a clean work space and some clean rags.
So lets get started......
If your carbs are really dirty I suggest a spray with brake parts cleaner first and a blast with air. Remember the gloves as the parts cleaner is hard on the skin. I also would snap some pictures so you can see how the hoses go back on.
As you can see these carbs are very clean and are from a 1997 GSX. THey have the dreaded TEMPO gray fuel lines that rot from the inside and ruin engines. These do not have accelerator pumps but I will add that later.
I suggest marking the carbs as MAG for magnito/front carb and PTO as in Power Take Off/rear carb. I also mark the rod connecting the carbs.
Next we will remove the hoses...
If you get a little flat screwdriver into the crimp of the clamp and wiggle it side to side the clamp will loosen and you can pull them off, dont worry about dammaging them as we won't reuse them.
Here is the start of the green goo, it is caused when the ethanol in the newer fuel degrades the inside of the Tempo lines as it was never intended to be used with ethanol fuels. The goo makes it's way into the carbs and plugs the internal filters and starves the engine from fuel burning up the pistons.
Next we will want to record the carb settings for the High and Low speed screws.
The high speed screw is under the plastic cap at the top of the picture and it can be wiggled off with needle nose pliers.
The low speed screw is on the opposite side and has a Tee handle.
We are going to turn each one in, clockwise until they lightly stop, counting the turns in and record the number of turns.
Now we are going to remove both low and high speed screws. Make sure you get the o-rings and springs out.
Next post we will start taking the carb apart as it will only let me post 10 pictures.
