Date: 1-7-14
Time: 8:00 AM
Temp: -7.3 Deg F
100%: Some Liquid, mostly ice. no expansion. (Slurpee stage)
75%: Very little Liquid. Icy. some expansion, but no bulging of the container.
50%: No Liquid. Icy. some expansion.
25%: No Sign of Liquid. noticeable expansion, and the container is bulged. Engine damage is HIGHLY PROBABLE.
0%: No Sign of Liquid. noticeable expansion, and the container is bulged. Engine damage is HIGHLY PROBABLE.
Notes: OK boys and girls.... here's the one the really counts. I'm not sure if we broke a record... but this is much colder than a normal low in Pitt. The news this morning said "We haven't seen temps like this since the 80's." The temp listed at that data point wasn't the "Peak" low. At around 5am, the low temp got down to -8.7 Deg F.
Note 2: As you can see, the 0% and 25% are totally frozen solid. There is a 100% chance of damage.
Note 3: The 50% mix is the strange one. It's relatively solid, but it's wet. It's also expanded. Because of that, there could be damage to something like Iron, or some plastics that will get brittle as it gets cold. But, since the freeze would have been slow... I feel that if there is any air space... the damage may have been avoided. Regardless.... this mix is still in the potential Danger Zone.
Note 4: The 75% mix is very icy, but I could brake the ice with a light squeeze. So, I would say this is still at a safe mix, as long as there was some air space.
Note 5: The 100% mix is now at our "Slurpee" stage. It's thick and icy... but it will move with the slightest pressure on the container.
With this data point.... I feel the test is more or less done. If it was a few degrees colder... even the 75% would have been at the danger point.
Needless to say... the closer you are to the ideal mix of the antifreeze, the safer you will be. Remember, our 100% is the ideal mix at 60:40, and our %'s are dilution %'s. So, even at a 50% dilution... you would be ok with a typical Pitt winter.
With all that said, you should do your best to get the proper mix into your toys... but it generally won't be the end of the world as long as you get some antifreeze into them.
I will leave the containers on the porch until spring, and if we get another very cold day, I will post the results.
