Hey guys,
Ok so my question is, can you check/test the rectifier out of the ski? Like just the rectifier its self. I bought one for my 1996 gti 717 and wanted to test it before I put it all back together. The problem with the ski is this..... I bought a new battery and the ski ran great for a few hours. Didnt bog or have any problems. Then the oil sensor beeper went off. I checked the oil and it was full. Gave it throttle on the trailer and it had the normal white smoke. So we unplugged the beeper and went out. They came back about 15 mins later because another beeper was going off. It was the low voltage light. Started the ski back up and all the gauge lights flickered and the beep came on after it started. We didnt take the ski back out, didnt want to get stuck out on the water. So I figured its the regulator..... So do all the stator and rectifier test have to be done in the ski. I checked the ohm's of it out of the ski, got no reading on 1 yellow wire and got a reading on the other wire. I also have another 717 ( 95 xp ) and I pulled the rectifier out of that one as well because It seamed to do the same thing,( I got different readings on both rectifier ) got the 95 xp started, turned it off and the battery was dead and would start, could be a bad battery as I bought that battery last year, did charge it fully before we went out, but I have had batteries die like that before, but I have 2 95 xp's and I did have to replace the rectifier on the other one last year so I figured I would change it out just in case.... Anyways can they be tested out of the ski......?
