anthonymsaad
Brief look over is usually fine and only do so after getting it back from the dealership, just to make sure everything is secured. Do have to say, the SeaDek is AMAZING!! Have it on my boat and by far better than the carpet!! Very comfortable to walk barefoot on, still grippy when wet, and don't have to deal with mold issues. I am also not a fan of snap on carpet as when I had my Yamaha that had it, and pulled the carpet off to clean the mildew, I managed to slice my foot against one of those snap in receiver in the fiberglass. Then had to deal with a few of those connection points coming out of the fiberglass and trying to replace them or secure them back in. With SeaDek, it's something I am VERY thankful for!
Next time I am free, will definitely check out a transom light install. The listing issue is just when I have a lot of people and not really weighted evenly. But if I try to go fast and turn right hard, it just lists. Left is perfectly level and absolutely terrifying how well it turns for anyone on a tube. That being said, my steering setup could be an issue as I had the joy of finding out what happens when you lose one of the steering rod bolts. It's a lot worse with thrust vectors installed. The rod went straight back and under the thrust vector fins, forcing it up into the reverse bucket. Ultimately, I have one thrust vector flapping around and the other jammed up, with steering only to one jet nozzle and even then, it's restricted from the pole stuck. And with the reverse bucket jammed up, I couldn't go into neutral or reverse. Made for a great time trying to get someone off at the dock to get the truck and trailer. Almost hit a boat twice, hit the dock faster than I wanted to (thankfully no damage) and remembering that there exists a safety feature of not turning your engines on when not in neutral. One lousy bolt gave me such a headache and probably may have caused my steering issues. Since I don't know how to do the steering alignment, i'm having the dealership do it.
Anyways, glad you're enjoying the boat and the sound system! Very jealous of your 3 amps and amazing sound system! Hopefully you can find the fuel issue and the starting issue, but glad you can enjoy the boat again!
