JJinSC
Well poo, I replaced my grey fuel lines two weeks ago and while I was at it I did the fuse fix in my fuel baffle pickup. The fuel gauge has been working fine ever since except I noticed it started reading a little low a little fast. It also seemed to come off of full a lot faster than it used to but I figured it might be because I put the float back in upside. It didn't look like it mattered which way it should go in. There were equal distances to the mags from either end. Went for a good ride yesterday and it was working the entire time. I went out to the dock this afternoon after work to gas it back up and it is all the way down below empty. I checked the ohms and it is reading nothing. So either my float has sunk or by fuse bridge didn't hold. I checked the soldered bridge before reinstalling by pushing pretty hard on it with my finger and it held. I also noticed that there was something swishing around (little) in the float, but I could not find a leak so I tested, it worked and I reinstalled.
It seems to me that if the float sunk, I would still get something on the gauge, but it is below empty and doesn't even budge when I press the start button. I get no resistance on the ohms meter.
So what are your thoughts, has my float sunk or did my solder not hold?
