So my "friend" took my boat (2009 150 speedster) out for a rip yesturday and somehow sucked up a few rocks. He said he was able to get 2 outta the 3 rocks out but there is a third one jammed in between the impeller rod (I think I havent seen it yet I'm just going by what he said). If we were to get that rock out what r the probable damages that he done? I had planned on taking it out for my holiday tomorrow but now I am wondering if I should even bother.
Could be fine or it could need a new wear ring or worse yet impellerr could be bent to crap.
I started a new post, so as not to hyjack spetch - I hope that's okay.
I guess yesterday was a day for rocks. I put my 2006 RXP SC in for the weekend. Pulled up to a friends new house & bulkhead and ran straight into a mound of gravel, sand, shells and mud about 8" under the surface. Thank you bulkheading company!!!
I shut-off & pushed off, but it was too late - I had sucked some in.
At first she idled along fine at 1780 RPM - perfect for no wake zone. But when I gave her throttle she would rev all the way up to 7000+RPM but would not get up and go. Based on the noise, and vibration it was also very clear that there were rocks bouncing around inside the jetdrive.
I rev'd her a couple of times which seemed to clear everything out. I had some bits of white plastic come out the outdrive along with stones and other debris.
The result is that she now runs fine with the following "minor" changes:
1) On takeoff, she shudders, ever so slightly, just until she get up on plane - which is only a couple of seconds after takeoff.
2) She maxes out at 8000 RPM (like she always did) but now top speed is only 62 MPH rather than 65 (there is a 1 mile stretch of wind protected area that I, and others, can speed test and get similar results regardless of weather/water conditions).
The rocks that came out... yea, I'm sure they did some bit of damage... and based on my performance test above, I'm guessing a slightly dinged, cracked or bent impeller (???)
I'm more concerned about the bits of white plastic.
I'm no mechanic and have few tools to even attemt taking anything appart - unless I must.
I thought about bringing her to the local shop here in Surf City NJ, but at $450 for just a pre-season check oil/lube, I know I'm looking at big bucks for them to even look at her - much less repair. :willy_nilly:
Based on how she's runnning and what happened, I have the following questions:
1) Could the pieces of white plastic be sheared off of a plastic impeller or impeller housing, inside?
2) Could the pieces of white plastic be from the (dreaded) wear ring I've read about on this site but still have no idea what it is?
3) Should I be pulling her immediatly to determine what (if any) damage has occurred?
4) Should I just enjoy her till she either fails (not apparant that this will happen) or should I just wait and if she makes it to the end of the season, bring her back up north and check it out over the winter.
Any advise or help is greatly appreciated. :cheers:
Mike
