welbytrise
So this past week I decided to take the wear ring off and smooth out some low spots with jb weld to see if I could get back some lost performance due to cavitation. Got it all done and it looked great. Sunday I decided to haul it out and see how she ran and just like I thought, ran like a dream. Then all of the sudden at the end of the day heading back to dock, a grinding noise and then nothing. Engine dead and no way in hell was that motor going to crank. At first I thought the motor might have seized and thought the world had come to an end. Got a tow back the rest of the way and once out of the water, I crawled under and looked at the intake grate. Sure enough, that little flimsy pos grate behind the main grate broke off and sucked into the impeller. All that hard work I did the past week....for nothing! So I decided not to whine about it because I like working on things and it will just give me something else to do. Today I decided to start taking it apart because I had already sent my old impeller off to impros to get reworked and when it returned I would be ready for it. Ten minutes into the job and I'm in between a rock grate and a hard place. The stator is stuck to the wear ring and I have tried with the might of Zeus to pull it off but it seems to be jammed in between the rock grate and impeller. So I am a pretty handy guy but I need a little help designing a puller to get this stator loose. Also, what else besides the impeller, wear ring, and stator could have been damaged? As in what else should I check before putting back together? Drop the pump and take a looksee? Any ideas and knowledge will be greatly appreciated!
2004 Challenger 1800 240 EFI M2 Jet drive
