That's a spot where the paint corroded off.The coke didn't clean it ,it looked good to begin with,except that spot that's corroded.I cut a blade width away from pump.Thats why there's about 1/4 inch of bolt sticking out.The venture was the cheapest part to replace.But a ton of work saving pump and gate bracket.A 10 pound sledge and punch,about 20-25 good hits with map gas.Thats after pressing nubs down with air over hydraulic press.Needed more arbors to use the press to push bolt through,that's why I used a sledge hammer.ONE out and 3 to go.
Used vice grips ,map gas to remove bolt threads from pump.Looked like yellow lock tight was used.Heat and would only turn for a second,more heat.Repeat.....About an hour for those.Crazy!
Cutting here in this pic,I think,is important.Or maybe been thinking too much.Bahhhaha
