Trying to remove the Jet Pump from my 97 SPX, and it will not come out. I followed the service manual instructions, so I have removed the 4 nuts, and 3 tubes from within the jet ski. When I pull on the pump it tends to want to pivot up, but feels loose most anywhere else. I am assuming the issue is RTV/Sealant that was applied at some time (not 100% sure because I have not owned it the entire time). Would that cause this problem? Nothing else seems to be binding up, the driveshaft seems to slide as I pull on the pump as do the hose connections.
If it is the sealant issue, are there any good tricks? I have searched a little but it doesn't sound like there are too many good options for getting it unstuck. I saw the tools in the service manual, and I could see how a puller would help but I don't really have the welding skills to build it. The idea of using crowbar makes me a little nervous since I would be pushing off of fiberglass.
Thanks.
Thanks.
