SeptemberC
I am aware that sounds are difficult to diagnose when you are physically there and almost impossible when you can't hear it yourself but here goes my attempt to describe it to you. . .
At low RPM 2500 going around 10 MPH or slightly less I am hearing a sound that resembles two pieces of metal maybe vibrating against each other. Like a shroud is loose and vibrating. With the engine cover up you can not hear it. You can only hear it with the sundeck down. Opening the ski storage area does not make the sound louder.
My intake grate does have one of the fingers bent to one side considerably. My thought was that this slight disterbance in the intake water was causing some kind of cavitation.
Your thoughts?
Your thoughts?
