got it "running" after partial submersion, replaced shorted starter, replaced high pressure fuel pump inside vst, vst is getting fuel, will run for about 5 sec at low rpm, then die. could it be fuel pressure regulator, seeing as im getting 0psi at shraeder valve, even though i know there is some pressure when i take off the gauge it spits a little fuel out? Is there a way to test the regulator(other than at the shraeder valve)
