Im new here and have a question. I have a 2003 seadoo GTX supercharged. I sucked a stick into the prop and jammed it yesterday. I idled it to the boat the shore which took about ten minutes. I watched the engine temp which stayed at about 100 deg. which was higher than normal but I didnt get any alarms in. What do you do when you get something jammed in a prop in the middle of the lake?? I had my little boy with me so I was a little scared also. What damage could be done running the machine with a jammed prop?? Last is there some kind of clutch assembly or something that allows the engine to run with a jammed prop how does this work??
