gtoimpulse
Hi, any help is greatly appreciated.
I am not sure if this is normal, my boat turns easier to the right than it does to the left. The wheel also points right when going straight. I drive in the intercoastal which is full of currents and it has been windy, but I figured when I went back in the other direction that the reverse current would make a difference, it doesn't. Do I need to adjust the steering?
I also have higher RPM's on the starboard side by anywhere between 300-500rpms at all speeds, even at idle. The engines sound like they are spinning the same, could the gauges be off? Wear ring?
Are these problems related?
Thanks.
Thanks.
