jimmaki
I trying a tube of TefGel which is supposedly made especially for s.s. screws in aluminum around salt water and would like to switch to s.s. socket screws for the internal Mikuni SBN 38i screws. I just got the Vessel JIS impact screwdriver but I'd like to try s.s. socket screws with the TefGel although I realize it is probably overkill. Humor me since I almost lost a carb body with a check valve body screw that took heat, left hand drilling and an easy out to get out.
What I need help with is identifying the screw sizes.
Here is what I think they are:
Check valve body screws flathead hex socket m4 - 0.7 x 14mm
N/S retaining screw cap hex s.s. M2.5 - 0.45 x 8mm
Needle arm pin screw flathead or oval head s.s. m2.5 - 0.45 x 8mm
Check valve retaining screw button head or cap s.s. m1.6 - 0.35 x 6mm integral washer head
