popasodatastie
Ok i have had this 96 XP with the 787cc Rotax for about an year. I wont have spark on inital start up but after a while of waiting it will start sparking by some kinda magic. I've checked all the connections in both the front and rear electrical boxes. Once the spark is there then its pretty much is good it will run like a top but once you stop it and put it in the garage after riding it you can go out and try startig it and get nothing again.
I've tried cutting 1/4inch off the plug wires.
I've switched out the coil and tested it on another and that ski fires right up.
I've regapped the plugs and replaced.
What other parts should i test and how can i test the i have a digital meter and i can check resistance and volts.
