It looks like you have a silver engine and and a white pump so something has been swapped at some point.
It also looks like there might be oil on the oil pump lever where the return spring is. If you are leaking oil out of the oil pump arm the oil pump is done and should not be run as it could seize your engine. If it is leaking I would source a good tested used one from Westside Powersports Seadoo.
I would also install a new oil filter as that one looks pretty yellowed and old.
