despower
I posted this earlier (as voltage regulator problem - which it is not), so I thought I would repost.
To summarize:
06 Sportster LE - works fine when battery is fully charged (on external charger).
When left to sit for a day or two (battery switch turned off), boat gives a Code 5 (long beep every 58 seconds). Code disappears when battery recharged to full, or if boat ran long enough (20 minutes) to recharge battery.
Battery has been replaced (although old battery seems to be good), checked ground wires (look fine, good continuity), voltage regulator checks out, MPEM is brand new (replaced last season).
Any thoughts or anyone experience similar problems?
To summarize:
