MPEM Issues 1998 Sportster
owenray99
Hey guys, I'm having some issues with my 1998 Sportster. I had it cranking fine. Next day, nothing, I hear a single click when i press the start button that i think is coming from the MPEM area, I not solenoid. I have tried the following:
1. New battery
2.Good DESS Post continuity
3. New starter Solenoid
4. Checked ground wires.
5. Neutral safety switch is good
It will crank when i jump the solenoid. Not sure what to test or try next. Hoping MPEM isn't fried.
Here is a similar post that is the same issues I am having: 98 Sportster Dess or Mpem Problem. Need Diagnostic Help
Thanks!
Start by pulling spark plugs out and putting wires on grounding posts. Then try cranking it over. Does it spin up fine? Does liquid come squirting out of either or both plug holes?
Have you checked the starter solenoid even if new? With insulated tool bridge across the two large posts and see if the starter spins.
There is a yellow wire with red and green (or possibly violet) tracer colors that runs from the MPEM to the starter solenoid. Unplug this wire from the starter solenoid and connect the wire to a voltage sensor of some type. When you press the start button, if the MPEM decides all is well, it will put a +12V signal on this wire to energize the solenoid. If the wire shows 12 Volts when you press the starter button, then your problem is in the solenoid or the starter or both.
I suspect that the wire will not show 12 Volts due to the other diagnostics and replacements you have already done. If this is the case, next you must determine why the MPEM is not sending a start voltage to the solenoid even though you are requesting it via the start button. This breaks down into two parts. Either the MPEM is "bad" (unlikely) or it is not receiving one or more of the inputs it needs in order to energize the solenoid. In no case should you willy-nilly replace the MPEM without absolutely proving that it is bad.
The two most likely candidates for why the MPEM is not sending a voltage signal to the solenoid are the neutral switch circuit and the DESS, in that order. At the MPEM, the wire color from the neutral switch is red with a white tracer. The way the neutral circuit works is to send a ground signal to the MPEM. So, you must disconnect the neutral switch wire at the MPEM, connect a continuity meter to the wire and confirm it goes to ground with very little resistance. If it does not show a ground, then the task is to find out why and correct the cause.
The safety lanyard circuit is a real trick diagnose and I'm not real sure I know how to do it properly without a factory diagnostic tool. However, if your unit works like other similar units out there, you should hear two short beeps when you plug the lanyard in. If not, there is a problem with the DESS or possibly the neutral circuit. You need to get a free copy of the operator's manual as it gives you a list of the warning horn signals and what they mean.
One last thing to check and, really, it should be first on the list. Check all the fuses in the MPEM. There is one 5 Amp fuse in particular that powers the MPEM.
Let us know how you're coming along.
What if the solenoid does not jump?
I’m not sure what you are asking.
See what @Ed Clark said above. Awesome explanation.
The insulated pliers across the big terminals on the solenoid is the same test as Jumper cable from the battery to the starter lug. Just a way to prove starter has enough umph to spin the motor. Do this with no spark plugs installed. Without the MPEM and other stuff working you won’t have spark any way. If starter spins motor, do again with plugs in. Still spins then next test a I would use a jumper wire from battery terminal on solenoid to the trigger terminal on it. Remove the yellow wire with tracer first so you don’t back feed the MPEM.
Does that yellow w/ tracer wire have 12vdc when you push the starter?
