SeaDoo97GTX
Hey all.  Great to be a part of this blog site.  You guys and gals give the best advise and I truly appreciate it.
I have a 97 GTX with only 29 hours on it. I ride in a fresh water river in SW Ga. I never drive onto the shore line with the engine running and I never back off of it with the engine running. I always take extra care not to suck up sand or dirt or anything if possible.
My Doo has the same problem I have been reading on this site that others seem to be having. Engine runs great but when I give it hard throttle it sounds like I am spinning my wheels. The Ski does move forward but I have to feather the throttle to get it up on plan and then I can hammer down and it will go. The engine is not bogging at all. I can nail the throttle from a idel and it will tack out in half a second to 7500 or 8000 and start cutting out with the revlimiter. No not on the trailer, it will spin up that fast in the water. Like I said the ski starts to move forward but just seems like if I give it to much throttle at once it just starts cavataing or something.
I looked through all the post on this problem and I have personally checked everything I have read about to check. No trash in the intake. I have replaced the carbon disk and new steal plate on the drive shaft inside the Doo. (There was a small water leak there so I thought it was sucking air but after the test run today I guess I have not found the problem.) The wear ring in the pump to me looks good. There is no splin damage to the impeller side or the PTO side of the driveshaft. I just don't know what the problem is.
When I had the pump off today as I was changing the carbon disk, I looked real close at the wear ring. Very tight fit between the impeller and the ring. I did notice some small scratches on the walls but nothing so bad that I would think could cause this kind of problem. I hear no funny noises when I am running in the water. No wine or squeals or nothing. I am stumped and I do not want to take this to the dealer.
I am very good at turning wrenches and I can rebuild anything with the right manuals and tools. I do already have a shop manual for this ski so I am good to go on direction but I just am out of ideas on which way to go.
I hope you guys have some other idea I have not tryed.
Thank you so much.
Thank you so much.
