The last 3 weeks I've been working on the port motor on my new (to me) 1996 Speedster. This form has been a wealth of information and an enormous help in getting things back right on this boat. Finally gotta hit the water today and was pretty dang happy with the outcome. Boat ran about 42 mph top speed but it does need wear rings. Starboard looks pretty good visually (haven't gauged it)but is gonna be replaced; Port side has like a 1/4" gap so I know it's really dang bad and this repair should vastly improve torque and top speed.However, I have a few questions and concerns... Ur input would greatly be appreciated!
1) As soon as I put it on the water I was getting a lot of water flooding through the drain hole under the driver seat. What could cause this much water coming in? The black rubber flap on th back of boat is intact. It was enough that it filled up the storage compartment in the floor.
2) Speedometer started to work and I think with more use it will be fine. Port tach doesn't work at all and starboard would seldom jump around. Loose wires maybe? Just trace em back? Fuel gauge is working but not reading correct amount. Waterlogged float?
3) Port engine will not start unless I give it half throttle. Once it starts n runs for a few second I can back it down n it idles perfect! If more than a minute before I start it back I hafta give it half throttle again. Maybe another 1/2 turn on low speed jets?
4) Port temp sensor sets off the solid alarm. The motor on top is literally cool to the touch. Jugs get warm but not any hotter than the other motor. Sensor bad?
Once this is all lined out boat should be good to go. Thanks in advance for ur input n advice!
