VikingTrad3r
Hi All, first post.
I have a speedster 150, 255hp.
i had my supercharger rebuilt as a preventative measure at the beginning of last summer. I had 1 year of great highspeed runs in the bot and plenty of hours tubing with the kids.
We are in the boonies here and i do my own winterization. I was under the impression all i had to do for winterizing (it gets very very cold here, -40) was run rv antifreeze into the garden hose fitting and blow all the water out, replcing it with pink rv antifreeze.
Im fairly sure that is where i went wrong. We will come back to my intercooler in a sec.
This year i launched the boat after giving the bot a once over — oil was full and CLEAN — and it started immediately and appeared great. Unfortunately the boat would not go over about 60% power. It has a sort of rough surging at half throttle, and will not spool up to full power.
I hit the web, googled, found this forum and did the following:
1. cleaned the fuel filters, wasnt much of a cleaning but i did use wd40 on them and i made it so u could see through them. no change.
2. drained the fuel, thinking it was bad gas. It looked sort of straw coloured, yes, smelled a bit like turpentine suppose.
It was at this point that i decided id better check the dipstick, even though i did before launching the boat. it was clean. now its....milky.
soooooo. i removed the throttle body intake hose and i found residual water. The boat is now out of the water so i only ran it for 30 seconds and once i blew water out no more came in. i could relaunch the boat, and see if fresh water keeps coming.
However...that milky oil. I noticed while running the boat in the water, when i came off theottle quickly, there was almost a muffling sound from the engine. ....thinking when i closed throttle abruptly created high vac condition and it was sucking water maybe?
anyway, i know i need to suck the oil out and flush it 3-5 times until no more milkyness exists.
and i need to pull the intercooler and pressure test. Problem is I cannot find any diagrams or forum posts of where the intercooler is.
Can anyone help with a link to a removal and replacement of the intercooler?
Cheers all!
Cheers all!
