joelmatt89
I have a 1996 xp. I bought in the winter, so I couldn't drive it, first time in the water it nearly sunk because it was missing a clamp on the drive shaft. Now it runs decent but the charging system doesn't work. Here is what I know the battery has 12.2 V when sitting and 11.9-12.1 V when idling. I replaced the stator with a used one off ebay that came off a working ski. It looked pretty decent, I also swapped the recifier off of another working ski to see if that was the problem. Whenever the ski starts it immediately blows the 15A fuse that appears to run between the rectifer and the selonoid. It is the only 15A amp fuse I believe. The starter relay has broken twice so I believe there must be some sort of short somewhere, obviously, but does anyone know which direction to point me in. Does that fuse possibly indicate a problem area. I'm not sure what to test my wiring diagram has the wrong color codes so it is pretty hard to check resistance between alot of the wires. Some one please help me I AM DESPERATE.
