Someone must know code reading ...
NEZZA
Does anybody know how to read the codes on a 2016 rxt300 getting engine light now and again. It is not good at full throttle as it puts you in limp mode heading towards a banking..
Can't find the process of reading.
You can turn the ski off and back on and it is fine again for a while but then does it again
The process is in your operators manual and if you don't have one you can download it on the Seadoo website
Thanks I have tried but nothing is coming up. As the fault is not there constant. So I guess it clears when I restart it.
I'm wondering if it is the wrong octane fuel I have put in this time
There are really only a few codes that clear after display , I know engine temperature , exhaust temperature and oil pressure are some. Maybe others here know what else they are and can chime in. Check your oil and fluids according to the owners manual , a clogged pump screen will make the exhaust temp go high.
