kwellmancpa
Just did a complete overhaul on this ski. Put in a new long block from SBT, pulled the petcock out and cleaned, pulled the baffle out and cleaned, new fuel lines, carbs rebuilt and a new diaphram. As recommended by SBT, still running the premix in the tank, and also my injector still hooked up. I reduced the premix as stated by SBT to allow for injector, but I think my injector is putting in too much oil, because not running right, and when pulled out of water on saturday, and ran to blow water out, getting a sludge like substance coming out the exhaust, a lot of oil. My question, not sure how to adjust the injector, the stock setting, and should I back it off some while running premix then back to original setting. Any help on how to adjust this would be great.
