Yes and no. When I've broken them before, I had the head stuck in the bolt and it was quite difficult to remove due to how hard the tool bit into the bolt head. I'd like to remove the chances of that happening again. Tool will be here Fri, I can wait.
Why not just take a hose lose somewhere to drain the antifreeze, leave the bolt alone? I'd put $5 on if you drilled a hole through the bolt it would probably back out without too much effort.
Here's 2 broken extractors I still have laying around. As you can see both of them broke. These are awesome for screws and small items, definitely not strong enough for this situation.
Those speed out type work best with a impact type drill. Heat it first though
They don't make tools like they use to. That Chinese steel is cheap, soft or brittle. Try an American made tool if you can find one.
If the bolt head snaps off then just drill and tap it back to the original M6 thread.
Ahh Ok. I just assumed they were all the same as my 09RXTIS. Mine is a M6 socket head cap screw (Allen head) with a brass washer for sealing.
When you get it out, take a pic and post. I have never seen a socket head cap screw with tapered pipe threads. My curiosity is now peaked.Good Luck.
Good work man, I guess some anti-seize compound rubbed into those threads might keep this from happening again, or even some teflon paste thread sealer (basically a lubricant). I know you already considered this.
Hanson I see, really nice design with low taper and high flute count, I like that set. Yep, good quality tools designed for the purpose really make a difference.
Next project is to replace and service wheel bearings and seals on trailer. Never done one with 4 wheel disc brakes. Some of the bolts look a bit "stuck". I'll be soaking them with some 50/50 ATF and acetone a few days before I begin and hope for the best. Lol.
