JPass
So I decided to flush my cooling system and replace the coolant being that the manual states this should be done every 2 years and our boat is 4 years old with no idea if the coolant is original or not.
Stated with the starboard side motor first (good thing) and everything went perfect.
Move to the port engine and I stripped the hex head bolt at the heat exchanger. No worries, I have easy-outs and other bolt removal tools. Not so fast said the bolt. I've been soaking this thing for days in Kroil and other penetrating fluids with no luck. The easy out bites, but won't budge the bolt. I'm worried about applying to much force and braking the tool.
I even ran the boat yesterday and had the tool ready when she was trailered thinking the very warm metal may have loosened it's death grip......Nope.
I called the local dealer and he won't touch it cause it's a boat and they don't work on the boats anymore. I tried to explain the vehicle shouldn't matter as all I am asking for is to remove the bolt, but they refused to touch it.
Not sure what I am going to do now. I guess I'm going to try to find a shop to remove the bolt. Hope it can be done without trashing the heat exchanger as it seams to be glued to the hull really well and would be an absolute nightmare to replace the entire part.
Any ideas would be greatly appreciated.
