Venturian1
Good post! There must be a lot of vacuum around the driveshaft, and if air can get in, it will.If the boot does not hold the carbon seal firmly against the stainless steel hat then air can leak into the jetpump during hard acceleration. To replace the boot you need to remove the driveshaft and you will be able to inspect the mating surfaces of the carbon ring and steel hat. If either surface has deterioration then it would be best to replace all the parts. If you accelerate hard from a dead stop in a straight line does the engine Rev real high and then it takes off after starting to move slow at first (like a slipping clutch)? That is the problem I had with a 96 GTX and replacing the boot, carbon ring and steel hat solved the issue. I also use a neoprene ring to seal the jetpump to the hull because that is another place where air can leak into the pump.
I prefer the old needle bearings and rubber seals, and a grease zert.
