Siphon tube for bailers
manolocross
Ok so I take a look in my buddy's jet pump and the siphon tubes are gone and he had a bit of water in hull after a tow. My question is what is the part number and where can I purchase these?? I checked eBay and they have part nbers and diff lengths so I'm stuck!!! If I purchase the long ones can I just cut them down??
I'm sure almost any tubing from your local hardware store would work, as long as it's the right size. Take one of the bailers to your local Ace or whatever and just get some tubing by the foot.
It's not the soft rubber tubing... It's two hard plastic tubes in the jet pump nozzle at rear of ski... If these parts are not there instead of removing water they will pump it in!!!
I got 271000464 from eBay ... Do you guys think these will work?? I think they are all the same just diff lengths ???
hmm,dont know,the 1133's are about 2 inches long,total length,
parker yamaha,928-669-2549,they will know for sure the difference if any,5 buks for 2 tubes
if you have a bilge , you could always just tie the two hoses inside the hull together using one of the 90 degree fittings.. so much for the stock bilge , but hey.. thats why i have a Rule.
