Should I replace needle bearings, if so, how?
scooper77515
freebie fixer
Premium Member
Got the impeller out, oil is black and stinky, but not milky, so no water in there. Bearings look and feel fine, but I ordered a new set before disassembly and figured I would swap them.
Should I, and if so, should I tackle this myself or take them to the shop and let them do it?
I don't have the bearing removal tool or the installation tool.
I thought along those lines...but after seeing how much salt this engine has been exposed to, I bought new bearings assuming the worst before teardown. Snipe is going to help me with the bearing swap, so I am confident I will have a good job done on them.
Putting in a new Skat-trak swirl impeller and wear ring, and figured I may as well do the bearings while I am in there.
I do understand your logic. The only reason that I would have taken a diferent aproach is because these boats will not nickel and dime you but they will $50.00 and $100.00 bill you to death and I try and save the money for a positive problem that may arise later because problems will surely come and they will not be cheap. :cheers:
