JK230SP
I recently had the shift handle on my 2012 230 SP snap off in my hand. Upon removing the trim, I discovered that the vertical lever broke just below where it inserts into the horizontal handle. Since it is a cast part, there is really no way to repair it.....and because there is no source to buy the shift lever by itself, I ended up buying a complete shift/throttle assembly for around $700. Such is the pain of owning a discontinued, 9 year old boat. Besides, I am betting that replacing the entire assembly is infinately less difficult than pulling the entire assembly apart to just replace the shift lever.
I was debating if I should wait until my year-end maintenance trip to the dealership to have the shop replace the assembly (duct tape is keeping me in business during the boat season), or if this was easy enough for a non-certified mechanic (me) to do while the boat is still on the lift here at the lake. I don't want to screw up any of the linkages, cables or lengths and therefore create more problems than I can correct. I have found nothing online regarding how to do the swap-out, or how much disassembly will be involved to gain proper access to everything involved underneath the right hand console. It would be my luck that I would lose contact with a cable somewhere into the hull, and then I wouldn't be able to get the boat onto the trailer...
Does anyone have any experience with this exact assembly? Instructions/diagrams/advice? Attached is a picture of the new assembly.
Many thanks to the people here with more experience and smarts than I have....
JK230SP
JK230SP
