Hi, I was out on the water this weekend and the port side motor started to lose RPM's while the other motor was running fine.This happen over an hour or so of running the RPM's just kept getting lower and lower. When running sometimes the would shoot back up to normal and then drop back off agian. It was also hard to start. I tried to start it yesterday and it would not run it would almost start just for a second or two. Replaced plugs and they are getting fire. The plugs are not wet with fuel from tring to start. Could this be a fuel pump or filter problem any idea's?
Thanks Kent
Thanks Kent
