dgoodwin10
I figured I would start documenting this build early, since it's still in the planning stages. Some of you may have seen my '96 XP build, found here: http://www.seadooforum.com/showthread.php?71268-SeadooDAN-s-96-XP-build-thread
I got this trailer on that deal and aside from some usual wear and tear things, its a great little trailer to the normal person. But when it comes to trailers, I don't know how to leave well enough alone. I would consider myself a 'hobbyist' welder and I've built a few utility trailers from the ground up in the last few years, and though this one isn't quite that extensive, I have some big plans for it. Now, onto some pictures of my next...victim.
I'll have some better pictures of the trailer later since its back home while I finish up classes this summer. And yes, I am a college kid, so this will be done on a budget.
The best I can tell, this trailer was used to haul a pair of 3 seaters, judging by the winch position, which brings up my first issue. This trailer will be toting a GTX and an XP, so the XP will be sitting pretty far forward on the trailer. The current winch system is totally adjustable and works well, but it isn't the cleanest system ever, nor does it accommodate 2 different skis very well. It also is running 8" tires, which have got to go. I know they would probably be fine, but I would feel much more comfortable with some 12"s, which would also match my single trailer that the GTX is currently on and allow me to run a single spare. The trailer also has no storage, which is probably the biggest issue. i want a place to keep life jackets, oil, gas, tools and all that junk. So with all that being said, here is my current modification list on this trailer, in no particular order:
First, I'm going to order new hubs and wheels to fit my current axle and swap those on. I'm going to pull the winch assembly off and weld in new cross members to accommodate a different winch setup, very similar to the Shoreland'r and iMove trailers. (I'll post a picture when PB is back online). And now comes the big one, which will happen before the winches: making room for storage. With a different winch system, I might have room to clear the toolbox, which I already own, but I'm not counting on it. My plan is to cut the frame right in front of the axle and add up to 2' to this thing. Don't worry, after I box in the channel and plate the outside, it will all be fine. For mounting the toolbox, I'll make a frame out of angle iron that will be welded to the trailer and the box will sit in and bolt to. Last, it will get new bunks, a walk board, lights and who knows...maybe a few other surprises! So, stay tuned for this build. I'm definitely excited about it. Questions, comments, jokes and criticism are always welcome.
