First off, I would like to thank everyone on this forum as I have done a ton of trial and error after reading the available posts/threads on this exact topic. I have a 2001 seadoo speedster with 240 EFI. The oil tank is on the port side of the engine if that helps determine which engine version we are talking about. I have spent a ton of time getting my boat perfect and am a bit obsessive with making it perfect (I've attached a pic to give you an idea). Just some of the upgrades in addition to cleaning/buffing the boat to within an inch of its life are the stereo, amp, tower, rack, and speakers. The issue that I am having is that the boat smokes excessively at startup as well as once idling for a while. When I take off after this idling period, the engine is clearly loaded up with oil and hesitates a bit before clearing out the oil in a puff of smoke and finally taking off. If I don't idle for long before accelerating, the boat takes right off and goes. After coming down in rpm (from above 3k), the boat will run clean for a few minutes before going back to the loaded up smoky state. I am aware that two stroke boats smoke, but this is way too much and completely embarrassing (I have been in other mercury EFI two stroke boats, including another seadoo with the same engine, but different hull - none smoke nearly this badly). Before anyone asks, these tests have all been done under load (in the water, not on hose). The boat runs gps verified 52mph and I just rebuilt the jet drive this season (stainless wear ring by impros and reconditioned prop that was already in excellent condition). I have owned the boat for three years and this problem has been consistent throughout the following attempts at correcting the issue:
-replaced port side temp 13536A14 twice with thermal paste (thought there may have been a chance I was sent a bad one).
-replace spark plugs each year with bpz8hs-10 (I have heard I should try BUZ8H or champion ql77jc4 - is that correct?)
-replaced all three fuel filters
-running quicksilver premium plus two stroke oil
-had mercury dealer in NY (alex's marine plus) inspect boat, recommend replacement of oil pump. replaced pump at cost of $350 and another $350 of labor with no change). Also confirmed the pump setting was on the correct mark
The only other symptom of the boat (it generally runs very well otherwise) is that it can be a bit difficult to re-start once warm. Once cooled off (or fan run) for a few minutes it starts right back up. Not sure if this was related but figured it may be relevant. The last thing I haven't checked is the TPS, and it seems that from some discussions that may the culprit. I just became a premium member on here so that I can look up the manual and instructions on checking it (I'm not great with electrical although I'm a solid backyard mechanic). Any tips/pointers on other things that could be contributing to the issue? Thanks in advance everyone!
Thomas
Thomas
