Seadoo no start
Milroy16
I have a 97 gsx 787 and was riding it and worked well for awhile but then it started to just die then went to take it out again and pressed the start button and none of the gauges came on or anything. Gauges come on when I put the key on though. Is this a bad button?
This really needs to be moved out of the performance section and into the regular two stroke section of the forum...
You need to take a multimeter and test the switch. It should just be a contact closure, so check to see that you have continuity when the button is pressed and none when it’s not.
