SeaDoo boat handling
thebulldog
Hello
I bought a single engine boat a few weeks ago and
Am looking for info such as .... How do you approach a
Wake or wave , cut into it head on and power higher ?
How do you approach a dock with other boats that are
Moored up without hitting them ??
Many thanks in advance
I think you should try to go for online solution. I have an idea to moored up the boat with hitting but without hitting I just have to research about it.
You should add they type of boat to your profile. A question like this should be in the boat section. Let me know, and I'll move it.
But... Generally... the small seadoo boats can hit a wave/wake any way you want. Obviously, if you hit it straight on... you have less chance of getting wet.
As far as docking... it takes some practice... but a jet boat is more maneuverable that a prop. Basically... you will rock the control lever from neutral to forward as needed to control your speed. Then... put it in reverse, and give it a shot of throttle to stop.
