Rossco986 Active Member Apr 23, 2019 #1 My seadoo runs fine but sounds like it isn't idling sounds like it's running on both cylinders on startup . Can anyone help please
mikidymac Moderator Staff member Moderator Apr 23, 2019 #2 The RFI skis will idle rough when warm because they only are using one cylinder at idle. You can try replacing the spark plugs but if everything else is fine then it is just the way they are.
