rterry6256
The ski runs good until hot, (I don't let it get to hot). Engine pistons ok, fuel system revamped, carbs rebuilt, lines changed, valve checked etc. I feel the problem is in the oil or water system. I just found the oil lines are reversed going to the rotary chamber. (This is the correct set-up: bottom of the oil tank to the port side of the engine. The return (vent) is on the bottom of the starboard side, under the carbs and that hose re-attaches to the top of the oil tank, where the vent is.) Could this cause my problem? Also how can the water passage system be checked without disassembly?
