Sea-Doo Superchargers require a rebuild every 100 hours or 2 years (which ever comes first). This is a full rebuild service for Sea-Doo Superchargers; you purchase this item, remove your supercharger and send to us. We will rebuild it and send it back.
There are 3 primary reasons to rebuild your supercharger:
- Prevent bearing failure. The impeller spins are speeds up to 50,000 RPM, and the bearings are rated at 2 years or 100 hours.
- Prevent washer failure. As the clutch wears, inducing additional friction and heat to the washers, which can cause a catastrophic failure.
- Restore Lost Performance. When the clutch slips, the supercharger isn't able to make full boost, thus robbing your engine of performance.
This is a rebuild service, meaning we will rebuild your supercharger and send back your supercharger.
We can ship out of the US for the additional cost of shipping.
Turn around time is very quick; we usually have each supercharger rebuild within 48 hours. Powder Coating will add an extra week.
Options:
Viton Oil Seal - Only required if you have an upgraded supercharger. Viton Oil Seals can handle the additional heat and prevents oil from leaking into the intake track.
Performance Impeller - We will install any performance impeller at the time of rebuild for no additional charge. Click Here for a list of Sea-Doo Supercharger Impellers.
Powder Coating - If your supercharger's finish is chipping, we offer a durable powder coating option. Keep your supercharger protected from the elements and lasting longer; this service can only be done at the time of a full rebuild, since the supercharger must be disassembled. We offer Black or Red for our standard service. Contact us for custom colors.
Click Here to get your Sea-Doo Supercharger Rebuild Service!
