naturally, here, the ethanol have 2% of wate add in composition.
I will make a test, if not work good, i will back to use gasoline.
I like ethanol because in all engines that i converts, all get more horse power, the engine works more sharp!
for change the ignition time, what i will need? If i like just to remove the speed limit whats i will need?
I buy 3 units of siemens FI114357 fuel injetor 45lb for use in ethanol, buit in gasoline, this 45lb is better?
thanks
