Sea Doo Customer Service
smcnair
So I need a part for my ski. Sea Doo changed the part number on it (added an "a" to the end) and more than doubled the price. My dealer asked them about it and they said it was so they could make more on the individual parts - I kid you not. Even with that, they still can't get me the part.
This has taken a month of my summer with absolutely no help from the manufacturer.
I started a Facebook page to vent - Sea Doo Customer Service is Terrible
You can find em all day on ebay and other places on the net for a fraction of what they want. You can find it around 200. Im pretty sure just about any newer 4 tec 155mm pump will work.
apparently not. I searched every listing on ebay and could not find one that would work. I have contacted about 40 dealers and none of them have one that will work.
Also there may be a price difference because they have some that are all metal with aluminum and bronze and some that were all plastic. I would guess that is what you are seeing.
There are a bunch that will work. The main difference in the 155mm pumps is some were all plastic and some were metal. the end of the shaft were the impeller connects is slightly different on some of the newer skis, but they essentially have the same 155mm pump.
If you know of any part numbers that will work I would love to give that a shot. The one I was told would work and ordered was 267000417 and it was not even close to the 267000269 that is what I need. It had holes in the side and back like the venturi tube has for the hose. The venturi would not connect and the housing did not have holes to screw in the wear ring like the original.
