Welcome to the forum...
No, the 951cc engine is a completely different engine, by design and electrical system. You would have to change out almost the entire electrical system and the 951 mounts would have to be fabricated into the boat to fit, since the engine is different.
The original engine, the 787cc (called the 800 for convenience) is the boats design engine and although there are some modifications you can make to the impellor for a bit more speed, I don’t know if the pump your wanting to try could be modified to run on the 787 Rotax.
Good luck though and tells us what you decide to do!....
