I went with the SBT wear rings instead of OEM. It's a much tighter fit to the impeller than the old OEM ring was. So tight in fact that it binds up just a bit. Not much, I can still turn the impeller easily by hand, but it is shaving a very very small amount of plastic saw dust at a certain point where the wear ring is contacting the impeller. Is this normal? I assume the impeller will fix this problem in virtually no time at all once I start the engine by "sanding down the wear ring. I just wanted to make sure this was ok and that the wear ring wasn't out of round or anything. Its a very, very tight fit and probably only hitting by a few thousandths or so.
