Toolanddiemaker
I was going ahead on a top end rebuild because of bad compression readings and I noticed sand in the jug sides is this something to be concerned about? this is my first time rebuilding a boat so i'm a little unsure of a few things I think it's ok because those sides are sealed away from the engine ports but I just wanted to make sure. I flushed the engine before storing it in the garage but flushing must not get thick sand out? on my last run I did hit bottom sucking up rocks and destroying my impellers:facepalm: so I guess I get why its there. I don't see any trace of sand in the pistons just the jug sides. any suggestions thanks!
