RX di running issue
pros600
02 di ski starts and stalls.wont stay running .it has over 100 psi fuel pressure a 140 lbs compression 2 beeps when tether is put on fuel pump runs for 2 sec at 28 psi when tether is put on.any help would be great and thanks for looking
problem solved.the person that installed the new engine mixed up the 2 air injector connectors.switched them and all is good.thanks
Hi , just joined the RXDI forum and my RXDI MPEM has succumbed to the dreaded diode short that the MPEM is known for . So I've managed to depott the MPEM and I've located and bench tested the diode and my friend has confirmed that the diode has indeed failed !
I'm going to hopefully get the new diode repair done by next week so if it works it will have cost me all in all £15 and a lot of hard work. I'm just posting this in case you or anyone else has this issue !!! Enjoy the summer
