ok when my seadoo is just idleing it runs fine for 15 seconds and then shuts off and i turn it back on it runs then shuts off like the rpms start to drop and turns off but if im giving it gas it wont turn off but when it idles it will shut off? what could this be
and the gas is from last season idk if that will effect much same with oil
and i have also had a multi meter hooked up to watch the battery when i give gas it goes 13 to 14 but when idle its at 12ish but i do see sometimes when the engien is about to turn off the volts go down to like 10 and less and it shuts off idk if this could be problem battery was tested works fine and i took it off the charger been chargin 2 days and ski still shuts off when idleing
oh and it does seam i have a small exhaust leak on the inside could that be it? and tips on how to take exhaust out
