I have a 2003 gti le with the 717 engine. It has fire and compression to both cylinders but is only running on the front hole. I have not tried to take it apart yet but was thinking it could be the rotary valve. Please help.
If you have access to a compression tester, check the compression to make sure it is good. If comp is good, remove the plug from the running cylinder and swap it to the non-running cylinder. You can also cut the plug wire back 1/4" or so. Sometimes they get corrosion in the end where the boot is and can cause weak spark. Good Luck, keep us posted.
Do you have only one carb as this is what I would think that you have. [But I can allways be wrong]. If you have two carbs I would say the the carb that is conected to the no ignition cylinder is the problem. I think that you only may have one carb if so and you have good compression I would say that cylinder that is not responding is due to bad plug or wire if this is a wasted spark system. I can only guess that it is. Good luck Robin :cheers:
