Hey guys just looking for a little help with some trouble I'm having. I've got a 2000 speedster SK with the 240 efi. Serial number OE38298. My problem is that it starts and runs just fine when it's cold. Smokes a bit but that seems to go away after it heats up. The problem is that after it gets hot it doesn't wanna fire up again. I run the blower on idle and even about a minute or two before I know I'm gonna stop so I don't think air is the issue. It's like the bendex kicks out before it will turn over. If I wait 10 minutes it's a bit better but I got stranded in the water for a while so I bypassed the solenoid and it fired up even better than it normally does with the key. I replaced the solenoid. That didn't help. I replaced the port side temp sensor. That didn't help. I replaced all the spark plugs and that helped run smoother but not my starting problem. Compression is 125 on all cylinders so that isn't the issue. I thought it could be the tps but I'm going to test it with my volt meter before I drop 600 bucks. Any help is appreciated
