02_SEADOO_RXDI
Hello everyone.
Last weekend, I did something that I didn't expect to happen. The wake boarding rope was under the jet ski when I clicked the start button, and so it was pulled into where the water is pulled in, and was tangled up around the drive shaft. What exactly happened was that the engine started up for about half a second and shut off. I am concerned to why it shut off so fast. Could it be a fuse or something? So what we did, we pulled the sea-doo to the shore and lifted one side of it up, and one of us with small hands untangled all the rope out with out any tools. I noticed that this plastic piece with a tiny propeller which is located directly to the left of the rear jet had broken off. It looks like the small propeller thing has to do with calculating the speed on the speed gage, but not sure. So we thought, now that we have untangled the rope, we can try starting it. We put the key on, and heard the normal beep that all sea-doos make, and then clicked the start button, but then all the gauges turned off and it pretty much shut down. We didn't even here the engine start, it all shut off. and this time it was not making the beep sound either. So now, I have a feeling that I need to check the fuse. But before that I know I have to take out the spark plugs and make sure there is no water in the engine and stuff.
I have only had this Sea-Doo for about a month, so I don't know what I really should do. I would really appreciate any tips or suggestions. I can give you any other info if you need it.
Thanks to all.
Thanks to all.
