Spoody6677
717 gs engine, do piston rings have a orientation on the piston end cap, seems to confuse, please make it simple in reply
End gap, not cap1st groove nearest pin, 2nd groove
OK, let say starting groove #1 being coming from bottom of pistonIs there not a locating pin in each groove?
omitted this part of thread1st groove nearest pin, 2nd groove
gap sorry type error is the orientation maybe 180 degree, from other ring717 gs engine, do piston rings have a orientation on the piston end cap, seems to confuse, please make it simple in reply
Is the end gap location, 180 degree from other rings end gapI’m not understanding, I’ve only ever rebuilt using single ring pistons. Your using a dual ring correct? You have 2 rings for each piston? Is there a locating pin in each groove on the piston?
Is there a over counter that I can substitute for 518Follow the service manual.
Gaskets go on dry, cylinder o-rings get 518 and use the loctite and grease on the correct bolts.
